Hello.
This is second machine we retrofit. We have problem with the Z Axis. When we run program for drilling or other program where there are a lot of Z movements, the Z Axes is slowly going deeper and deeper then it needs. The encoder is ok and shows that everything is ok. I tough it might have some loose parts but I checked everything and all is ok. Everything is tight.
When I zero the Z axis in most down position and when I go up, then go down at zero, the KMotion shows that the Z is at 0 and the encoder is 0 but the head mechanically is about 0.1mm deeper. Then if I repeat this process, the head will be 0,3mm deeper and it goes down. It is not exact value. Sometimes it is 0.15mm, 0.4mm, 0.32mm. I can't find pattern. What could be the problem?
We are using software version 4.33l. I am really confused. X and Y are fine. Z is connected at channel 2.
Please help me I am running out of options.
